- Aug 9, 2012
- 11,528
- Name
- sam miller
RA secret formula his grout master looks identical to oxyblaster and they use it to boost prespray.
Abuse of the word secretRA secret formula his grout master looks identical to oxyblaster and they use it to boost prespray.
I'm thinking of just a simple 20% extra effort and chemical tax for pet jobs. If the cleaning is $300 the additional fee for pet conditions would be $60 and this is not optional. Your total is $360.00. I'm just thinking out loud here, never done it this way.
RA is Rob Allen?RA secret formula his grout master looks identical to oxyblaster and they use it to boost prespray.
I disagree as well....as Mark was jus as crazy the first day he stumbled into this loony bin as he is today....
Chems or not Mark is a great asset to this forum. .....
' cides he's buying us a big fast boat someday....
Peroxides are great on contaminates. You cannot legally say it disinfects or sanitizes to government standards, but you also cannot say that it does not do some great cleaning on urine and its contaminants. I love peroxide, but it is very difficult to formulate, keep stable and get customers to buy regularly in small amounts. All peroxide products will sour when stored improperly and kept too long. Buy at most two months at a time. We know of customers who bought too much stock, stored it improperly, and started to have sour smelling product after a year.
oh my garsh .....that sounded so "Cobblike"
there's nothing "new under the sun"
just different formulations of the same ole sheeit that's always been brewed
enzymes and molecular modifiers work fine for cleaning garbage cans and dumpsters
But there's nothing better than peroxide (or mixed OTJ sodium perk) for carpet urine contamination ..period
Hi, do you mean 40 vol peroxide? Thanks, Pat
similar to Jim's custy, I had one too
From '92 til she passed of cancer in 2011 we cleaned her postage stamp sized lving rm, kitchen and hall twice a year that her little tea cup mutt fouled regularly.
She was embarrassed at times
What I told her?
"Dottie, you keep loving your little doggie, and we'll keep doing the best we can"
But the perc works to, ie osr type products.For pets use liquid peroxide as it is slightly acidic..
Use Sodium percarbonate ( increases PH) to boost prespray on trashed carpets.
Ok, great. Thanks for the clarification. I've been hearing about 40 vol, and wanted your input on it and the whole deal. I think its about 12 percent peroxide, and Im told one doesn't want to go beyond that strength.yep
I personally used more sodium percarbonate (essentially powdered peroxide) mixed on the job as needed
Simply due to being more stable/longer shelf life (in unmixed form) and more economical
since you're new here, Pat, I don't know your level of expertise/knowledge
so be advised, using strong oxidizers "may" bleach "some" carpets .
Pretty rare from my experience, but have seen it happen on problem stains of the "spray 'n pray" type ..that being spraying the persistent stains before you leave in hopes the stain will disappear by morning and pray the carpet dyes don't disappear with the stain .....
note in the above type use, only use liquid peroxide not sodium perc mix.
as sodium perc should be rinsed out due to soda ash left behind
.L.T.A.
If you don't mind dealing with your contaminated equipment and value a customer who's pets use the floors as their toilet, DONT say a damn thing, Just pre vac where you can safely, use your UV light with out mentioning it, hit the pee spots with some 40 and or some smell good product and just flush the carpet as best you can.
No water claw promises, no lectures, no mention of needing new carpet or pad, just pat the dog on the head and charge enough to make it worth your while.
They know whats going on most of the time, don't make them feel uncomfortable by pointing out how disgusting they and their pets are.
The second you start itemizing for adding a glug of deo to your HF or $25 per spot to water claw and so much per foot to apply a post Deo, you've probably lost them. They'll keep searching for that laid back cleaner who doesn't have to nickle and dime every job to get by, which probably means their search will never end unless the move to Gardnerville NV.
I say I'll just add some odorside treatment for the smell and peroxide to take care of the bacteria and staining and spray the noticeable areas really good, then give them extra flush rinsing when I'm cleaning. They take that 95% of the time. That's all they want is some extra love and attention to those areas and just clean it.
Pat
I educate my customers on everything from urine and other spills to replacement carpet and installation practices. So much that I have one carpet retailer call to ask me to stop recommending power stretching.Educating, not lecturing, the client about a potential problem in their home, is always a good thing. We all know that they've been exposed to unrealistic claims both by cleaners and products.
Not doing it because.......is nothing but patronizing.
Darn, I've been calling, and calling!!BLOCKED??If you call taking 400 phone calls a day from rookie carpet cleaners who need to know how many square feet 10 x 12 is for what he could have made in two jobs a month a Jack Pot than yes, hip hip hooray!![]()
Come on now. You can't say you have never been told to use vinegar? Granny's remedy!!One thing that I have learned in the last year (can't believe I didn't learn this in the previous 19 years) may be helpful. Most of the urine salts have ammonia as a base (odor encapsulants can deal with other odors as well as ammonia). The pH of ammonia is around 12. If you reduce the pH to below 9, the ammonia odor is neutralized. (You can see this for yourself wearing safety glasses and gloves for lab like test. Grab some ammonia and slowly add diluted acid to the solution) There are many products and methods out there, but if you include a strong enough acid (peroxide is acidic but not strongly acidic)in the process somewhere, you can reduce the ammonia odor and use less of the expensive odor encapsulants. An acid rinse may not be strong enough by itself.
You mean scolding, cause lecturing is educating. Informing, teaching, educating, lecturing, all synonyms. So, you must me scolding or something to make the person feel bad. Anyway, some good pointers in this thread.Educating, not lecturing, the client about a potential problem in their home, is always a good thing. We all know that they've been exposed to unrealistic claims both by cleaners and products.
If you equate educating to lecturing.......you must have gone to the wrong school or hung out with the wrong 'educational' crowdYou mean scolding, cause lecturing is educating. ..................
