Thanks everyone for your tips...like Dealtimeman said, there’s slush in my fresh water tank, so I set up a small electric heater warming up the heat exchangers. Hopefully there’s nothing wrong, but being a brand new unit with 32 hrs on it, i got worried.
damn
as mentioned, make sure it's
"COMPLETELY" thawed out before firing up
and give the guy a break, fellas
He's in Huston ..he's used to a hot humid hellhole
if your truck is parked in a garage, a $20 1500wt ceramic heater will suffice
MAKE SURE to use a 12ga extension cord in the shortest length that gets you there
(no cheap 16ga crap cords)
if outside in windy conditions , two may be needed
Get all wet tools off the floor too...it can be 50 at the top of the van and 15 on the floor
I'll sacrifice a bUrd for you in hopes you dodged a bullet
(if I see any...they all flew south down your way)
Hopefully this won't be an expensive mistake that you;
a.) you weren't aware water freezes below 32
b.) that you don't check low temp weather forecasts
.L.T.A.
