When Your Customer Tries to Make Their Problem Your Problem
When The Customer Tries to Make Their Problem - Your Problem!
by Jim Pemberton - Fabric Pro Specialist
“I tried a few things to get this spot out. Do you think you can make it a little better?”
Our customers understandably have the habit of trying their own spotter (or, often several spotters…) before they call us. Its human nature to attempt to try a “quick fix” before a professional is ultimately called in to solve a problem. All of us do that from time to time.
"THIS IS THE RESULT OF A CUSTOMER WHO ATTEMPTED TO SPOT CLEAN A RAYON VELVET FABRIC"
Here are four things you must do when given such a challenge:
1. Be Courteous:
Never EVER scold or belittle your customer for attempting to spot clean their fabric. Instead, say something like this: “Its understandable that you wanted to get this fixed right away when the spill happened. I never call a plumber when my sink is clogged either! We will have to take some steps to remove the things you used, and its possible what's happened will keep us from getting this back to 100%, but we'll try”
2. Be Clear:
Once you've kindly “let them off the hook”, let them know that there might be some color damage. One way to approach it could be: “Sometimes the cleaning products you have won't know where the stain stops and the color meant to be in your fabric begins. I think we'll see some permanent color change after we've removed what we can of the stain. We'll do our best, of course. But any colors that change or are missing when we're done are out of our control.”
3. Be Careful:
Even though the fabric looks “ruined”, it doesn't give you the excuse to treat it carelessly. First, rinse out as much of the residue as possible, as you'll need to find out how much of that discoloration is distortion, how much is residue, and how much is permanent color damage.
Only after you remove as much of “their stuff” as you can, should you proceed with cleaning and stain removal processes. NOTE: Any remaining residual stain removers that your customer used may interfere with what you use!
4. Be Confident:
When you know you've done your best, even if the result isn't perfect, have the confidence in yourself to know when to stop, to diplomatically remind your customer that they ultimately were the source of the problem, and get paid for your expertise.
IF YOU COMPARE THIS WITH THE CONDITION OF THE CUSHION IN THE BEGINNING, YOU SHOULD FEEL CONFIDENT THAT YOU SHOULD BE PAID FOR YOUR WORK-
There isn't a better time to suggest the application of fabric protector on all of your customer's high value carpet, rug, and upholstery in their home. If properly protected, there should never be a case when a spill results in such a disaster, and they should be made to feel comfortable to call you if such things happen in the future.
todg
Las Vegas
Michael Marcus
I follow the same 1-4 guidelines you set! Very true! Being confident to me is the kicker! Excellent advice for any home based service business!
1. Be Courteous:
2. Be Clear:
3. Be Careful:
4. Be Confident:
Ne
In order to avoid all of the dialog just tell them to buy another piece of furniture
Reactions: ronbeatty
So true!!!!!!!!!!!!
I had a urine job that was so bad the base boards were swelling. When I see this I always take pictures of the pre-existing damage. It saved me. The customer called back complaining I damaged her baseboards. I had pictures handy of the UV light exposing extreme urine contamination and of the board damage. I never heard from the customer again after emailing her the "before" pictures.
Reactions: Jim Pemberton
randy
USA
Randy
Remember when cellphones didn't even flip yet, or ( in the case of those in Jim's generation) the 80 cents each polaroid before and afters ? Perhaps there was an excuse then for not taking before and afters in these cases, but now with pretty decent cameras on the smartphones it should be a no brainer.
Even on jobs that seem routine if the customer seems a bit demanding, strange or rude take the pictures. I read an article about a plumbing company that has body cameras on all his techs. That seems very invasive to me, going into a home and filming but after a false claim of sexual assault on a minor it became their policy. They actually advertise it on their website, explaining that "we must be sure that any new hires are conducting themselves properly and doing the repairs for our standard reasonable rates and not padding the job".
Not sure I like the approach but as society changes and technology advances it may become the norm. I remember sitting in an upholstery class at Pembertons a few months after the Sept 11, 2001 attacks. Lee Pemberton said, " everything just changed" and went on to explain the effects this would have on our industry and lives. How people are now scared and will be uncomfortable with strangers coming into their home. He was correct and already ahead of most on what we were and are facing. The drive home included a stop to the crash site at Shanksville, PA where they were still working the site for evidence collection. Although they kept you a few hundred yards from the impact site there were people gathered there constantly paying their respects and trying to cope with the " new normal".
