When I use a watts to HP converter, I get 1850 watts equals 2.48 bhp. In real life I believe 1.5 HP is the max for 120 vac 15 amp.
https://www.engineeringtoolbox.com/elctrical-motor-full-load-current-d_1499.html was my reference in this case
but even if we use your numbers you are searching for 8+ individual circuits to achieve the same work rate
so unless there is something Larry has that show a serious efficiency disparity or a lack of need for said work.............
