J
Jeremy Martin
Found a good deal on a TMT 3G which looks to be a relabeled SS2500. Any input from someone who's actually used one? This would be used for residential and light commercial only. Thanks for the input all!
From the little information I've been able to find it definitely appears geared more towards tile. 35hp KohlerIs that the tile machine?
@dealtimeman
Dealtimeman has/had one setup in a trailer. He loves/loved it.From the little information I've been able to find it definitely appears geared more towards tile. 35hp Kohler
It is a good unit with a badass heat exchanger rated to 2500 psi.
If you get the Briggs motor you need to have the heads/Valves adjusted every 100 hours or so.
If you have the Kohler than you don’t have to adjust the heads.
Good heat, good suck, more psi than anyone is going to ever need.
A work horse that will run hours and hours if you take care of it.
What else do you need to know?
Make sure the unit hasn’t been sitting in water and the frame is rusted.
They must be horrible if Pemberton won’t comment.
