- Oct 6, 2006
- 117,243
x590 is the one that has an insecticide component "effectively reducing and controlling" is my phrase, my pest control ticket has expired and I therefore make no claims of eradicationmicroban it with the one that kills bugs. Don't tell them you are killing them either then clean
Just haul it into the sauna room in your house.... that way, you got a comfortable place to sit..... AND, get work done at the same time.... multitasking....Heat will kill them. Exterminators raise the temp over 120 for a length of time, allow it to cool off so any surviving critters will come out. Then they hit it with the heat again.
Personally it wouldn't be worth screwing with for you or him.![]()
120 for 20mins to kill the hatched ones and hour and half to kill eggs if I remember correctly using heat, I sprayed and prayed.. that gift horse needs its teeth checkedHeat will kill them. Exterminators raise the temp over 120 for a length of time, allow it to cool off so any surviving critters will come out. Then they hit it with the heat again.
I'd do my minimum charge x2= $240 you'd have to love that "free chair"So how much would you charge for that? Double your rate? $29.95 x 2?
...so, there are no bedbugs in Arizona?Heat will kill them. Exterminators raise the temp over 120 for a length of time, allow it to cool off so any surviving critters will come out. Then they hit it with the heat again.
Please don't give up on Marty so easily!You just can't fix Stupid
They're less likely to stow away than fleas but also harder to get rid ofWere not licensed exterminators call RA I here he is!
Actually I would be more inclined to say dem bugs is bad news, and I can’t afford to have one travel with me to my next customer ever!
