sassyotto
- Jun 7, 2013
- 1,292
- Name
- Paul
my least favorite part of the truckmount - my Comet Pumpout. For whatever reason, I have to throttle down the machine for it to work. But I got used to that.
Now all of a sudden it stops working, well at least that's what I thought. So today I go into the waste tank and lift the float and it starts to run! OK, clean and reset the check valves, put water in the waste tank and turn on the pumpout. the pumpout runs but no water coming out the front.
Checked the hose going to and from the pumpout and both are clear of debris. So there is water going into the pump but no water coming out of the pump. Remove and reset the check valves. Still no water but pump runs.
Any thoughts as to what it could be?
