CRB
Ne
I use my CRB on commercial where it was designed to be used.
But not very often! My hoover conquest has an aggressive brush roll and using a CRB is a needless step
sassyotto
Wisconsin
Paul
been using a HOST machine as a CRB since 1981. Switched to 15" Brush Pro a couple years back. Only time I pull the HOST machine out is on very small jobs or where a 15" doesn't fit which is maybe once a month.
I thought I invented using the CRB with HWE but went to a Jeff Bishop seminar in Dothan a long time ago and he had it in his manual. Dang!
Grand Rapids, MN
Do you use the black brushes on everything?
These are the commercial Brown brushes probably in the video. They are a stiffer brush over the white brushes for this unit which are considered standard. We use the brown brushes a lot because we see so much polyester where we are at. We get into something nicer like a nylon we switch out to the white brushes. We do have black brushes for wool but I've only used them a few times. The black brushes for this unit are very soft by the way
Reactions: J Scott W
