- Oct 6, 2006
- 116,776
Now what....
Well if you used a brush pro at 7000 sqft per hour.Guess I’ll gave to go to Atlanta experience show to find out how.
Also very interested in cleaning 120 rooms in 5 hours, looks to be very interesting.
no employ lots of ethnic minorities below minimum wageGuess I’ll gave to go to Atlanta experience show to find out how.
I budgeted 12 hours with three guys. Hope I can pull it off.To them that is but a 6.5 hour job for sure.
2 trucks?
Better to have 4vguys 2 trucks for 30000+ size jobs, would schedule another guy just Incase the one you have gets sick, drunk, in an accident or whatever.
NoSo Tom and his son and you?
Using the emulsimorgification method?120 rooms÷4 wand 120 hp machine (30 rooms) each wand in 5 hours=10 minutes a room
Bfd all the apartment hacks can do 10 minute rooms around here.
Have you seen the dilution ratio on their carpet protectant? It's stupid high, and after my little testing I did with it...I laughed my ass off.
Ok Sam, here’s the difference between regular tap water, and RO... 2 cups measured, left on top of my deep freeze for a week.... just a little disolved solids in regular tap water? Wonder who is getting the carpet cleaner, with 1/5 the amount of chems?.....Wheres @Sierra Clean Care He swears by it!
One day I’ll go to local car detailed place that sells this stuff!
Let’s face window washers and car washer dudes need this so all the hard waters doesn’t make a mess!
But if we’re chemically charging our water doesn’t that help to?
@Shawn Forsythe or am I looking for @Tom Forsythe
I think Shawn is Daddy 2.0 now
Mike, take a pair of glass pie plates. Use a measured 2 cups (500 ml), take water from whatever source you use to fill your TM. Then go buy a bottle of AquaFina bottled water (filtered by RO), pour one sample into each plate. Let sit for a week. POST YOUR RESULTS HERE, so you all don’t think I wear a tin foil hat.how about with softened water?
Why dont ya just boil it down?Mike, take a pair of glass pie plates. Use a measured 2 cups (500 ml), take water from whatever source you use to fill your TM. Then go buy a bottle of AquaFina bottled water (filtered by RO), pour one sample into each plate. Let sit for a week. POST YOUR RESULTS HERE, so you all don’t think I wear a tin foil hat.
Jeff @ SCC
Because Derrick, this way it represents exactly what we do with carpeting...Why dont ya just boil it down?
