- Oct 22, 2012
- 28,210
- Name
- Ron Marriott
Just wondering what guys are using for pump outs, if using any at all. This is an old one I've had for 20 years. Simple and easy to use. Yes Ofer, I have more than one.
It works. I have had customers mesmerized by the dirty water.I think that came out more than 20 years ago. The idea was to show/plexiglass the neighbors all the dirt that was coming out I think. Suppose to help you get new business.
I've never used a pump out in my setup. I guess the portabilians know more about this stuffgood god you guys NEED my help.......REALLY!
Anything that you put in line will cause some loss in vacuum. There is a large filter screen running from top to bottom that keeps debris from clogging up the pump. Very simple and effective design. I only use it on large jobs that exceed my waste tank capacity. I can run all day without having to dump. I like the idea of having the built in pump outs but I hear a lot of guys have problems with them.Does it not cause any loss in suction due to adding blockage or disturbance in the vacuum flow? What about filter? Is there one in it that is needed, and does it get full of sand and debris?
Sounds too good to be true. I want one.Bawb-
You want simple?
You want reliable?
You want inexpensive?
...and it's out of sight inside the waste tank!
Got one that has no motor to ever replace, and will perform flawlessly for weeks with no attention to it's filter pumping 25 GPM even keeping up with flood jobs!
No where to park it here.Please, just go buy Mikey's Vortex for $12k . That's like $15,338.40 Canadian.
I'm waiting
Yes....i wanna see this magic apo with no motor you say is so good.....If you're asking about APO pictures, I am working on finding them, then I will post them.
I might, but I'll have to look for it.
The pump simply sits on the floor of the recovery tank. If your tank has a sloped bottom, place it at the lowest point. I put a knee-high over the pond pump's filter. I am able to operate for weeks without having to attend to it. It discharges thru a garden hose up to 150'.
The pump is a completely sealed elctro-magnet which powers a steel shaft impeller, so there are no motor parts to wear out. I have used one of these pumps for 14 straight years, only having to once replace the impeller ($35).
I do have a parts list of what and where to get them if interested.
At the end of the day, I place the dump hose (2" vac hose) on the ground and dump that last bit of dirty water back at the shop so crud doesn't accumulate on the APO filter day after each day.
I am currently using it cleaning at single digits with no problem freezing.
This setup is so reliable I don't know how I ever got along without it! I have it on my slide-in and my ETM. (Reliable to me, is to never have to worry about something going wrong as you are setting up for a job).
