Water stain on special silk...
Thoughts?
Roof leak....
Andy
No Where
Doesn't Matter
They probably got suckered into buying faux silk otherwise silk is silk. A real silk rug on the floor?
Reactions: Jim Pemberton
Bob Pruitt
earth
Robert Pruitt
Are you going to use compound?
Also since it's a rug...it could be removed from the large humidity controlled space and brought back to your rug cleaning shop...if you thought that was necessary.
Let us know how long it took to remove the spots.
just saying
Racine wi
Fritz rench
Try just one of the area...or a small part of
it...apply the "chemicals"/Pemberton...
cover the area ...has to breath and at same
time remind occupants its there.
Once you see it in person you'll know more of what to do.
That "water stain" seems awfully dark to be just that. I'm thinking there was something in the water (like coffee) or its browning from the cotton in the material.
just saying
Racine wi
Fritz rench
Yeh...might be just soil in what
dropped onto the rug.
Isn't there a pretty good chance the owner
would be delighted with a Pro
carefully "trying"?
Caused by a roof leak...
BIG issue here Mike:
There is all sorts of "stuff" that could be in the water from the roof, including staining materials from wood and other products. This is very likely a permanent stain. IF this were a synthetic rug, you could hit it with your nuclear peroxide, but it isn't.
I don't give this one much hope.
But...
What can my guys try since they're going out anyways..
