BEST Red spot remover
realclean
Jesse Lowe
I'm in need of some.
Who make the best red spot remover?
I'll be back later to vent about customers.
Harvard Stain Blaster works for us.
https://www.saigers.com/supplies/category/spotting-kit
Harvard was one of the original companies my understanding to come out with the first red heat transfer Chem
https://www.saigers.com/supplies/pr...l-aid-and-red-dye-remover/category_pathway-14
https://www.saigers.com/supplies/product/stain-blaster-12-x-1-quarts-case/category_pathway-14
http://www.jondon.com/harvard-chemical-stain-blaster.html
Screenshot_20180418-141650_Gmail.jpg Screenshot_20180626-202506_Samsung Internet.jpg
Jim Williams
Jim Williams
Stainblaster is good stuff. I removed one yesterday. I'm not sure if it was the Stainblaster or my superhero cape but the stain came out.
Pureforce red remover is all I use now. Great stuff. Tastes good too.
J Scott W
Jeffrey Scott Warrington
When comparing the red removers from leading manufacturer's, I suspect most of the variation in performance is due to the stain or the carpet fiber or the presence or lack of protector rather than how good a product works.
The best red remover is going to be fresh. Reducers do have a limited shelf life and time in a hot van during June or July does nothing to help that. Whatever product you use, keep a fresh bottle around.
When we developed RedZone Ready, we did a lot of testing against Red Relief which was the #1 seller at that time. 50 pairs of identical red stains on white carpet. Half cleaned with RedZone Ready. The other half cleaned with Red Relief. then a panel who did not know which product was sued judged the results. 42 of the stains were totally removed. No one found any difference. 3 of the stains, the judges picked Red Relief. 5 of the stains they judged that Red Zone Ready did the better job. Officially -We Won! Yea!
In the field, you will probably have similar results with any good product if you follow the directions and if you use fresh product. If it doesn't work, blame the lack of protector on the carpet. Don't blame the stain remover.
Reactions: realclean and ruff
We still use cobbs, we have tried others but cobbs is local and price is good, plus he has a newer one that doesn’t even require heat on some stains but does not smell pleasant at all.
Red 1 and red exit chemspec with a steamer can pull color out of the carpet gotta watch and be careful!
Red1 change the formula and that’s when I started having problems
Cobbs worked great without the color loss set it and forgets it!
If freshness as Scott suggests is the main ingredient.
It seems like freshly mixed reducer (from powder) (for red food coloring) will work the best.
I've done it in the past a few times, checking every 15 seconds or so on the progress, and it worked fine.
Anybody tried it more times?
