Do you think this will kill my WORX or IPS?
cape coral fl.
jack zerkie
Try swimming pool bleach 12% used in fl. to kill mold outside. Home Depot call it pool bleach about $4.00 a gallon or a pool supply. I sprayed it straight in a gallon all plastic sprayer. dwell time and rinse or pressure clean for good results.. jz
Nevada
Ya don't have gas pressure washer? You can always mix in 5 gallon and use your pressure washer
Bc
I’m sure you already know this Mike, but whatever you use to clean the cabin with, MAKE DAMN SURE YOUVE GOT PROPER PPE. Vapour mask, goggles, full rubber suite. You get that shyte on your skin, or worse yet, in your eyes, and your that far away from medical attention, this board will truly be the blind leading the blind....
