- Oct 6, 2006
- 117,240
those things, found in PMF internal uph and tile tools, ever plug them?
how did you unplug them?
Ditto. The 100 mesh in-line filter is a must for this tool and most others.I take a strand from my stainless steel carding brush and use it like a tee-jet cleaner, then blow it out with an air compressor. I use a 100 mesh inline filter at the quick connect. Very little problems with clogging.
It's really not that hardIf you go through all the trouble to remove that little thing, you might as well put a new one on
It's no trouble.If you go through all the trouble to remove that little thing, you might as well put a new one on
That's because of all the fibreMine is not plugged.
That's because of all the damn asshair.Tell the clue ball to flush his line at start up of eveye job and fouled jets will be thing of the past
CC'ers are stoopit
you can lead them to water, but still won't know how to wipe their damn bum
LTA
