1
1st choice restoration
im about to install some vinyl plank flooring in a rental property. We tore out some glue down carpet over concrete. Question is do I need to skim coat over the old glue residue or not?
Use a foam pad between floor and planks.
You're confusing laminate with LVP.Had an installer who refused to install those planks over concrete. Said they would buckle in a short time because of the moisture coming up. Do the fake wood planks with a subfloor.
