- Oct 6, 2006
- 117,232
I thought Damon put 3x as necessary and Matt was brewing his own potion. ☺
I just want to know what any of this has to do with chipmunks?
Lame trash talkingI love how these idiots get a brand new product and start boosting it with all sorts of shit before ever giving it a chance... like going to a restaurant and adding a bunch of salt and pepper and hot sauce before even trying the dish ..
Lame trash talking
Nowhere does that product describe having any relation to urine spot removal. So I tried mixing some vol40 with it. Shame on me
There’s nothing wrong with a little bubbly juice in the cotton candy waterCorrect, use another product.
Why would you compromise something you are testing A/B with?
you must have ate the whole fooking crib, I swear.
I think my water may have been too cold that day. I mix 36 oz at a time and use a 8:1 in a 7 liter HF. I get 12 gal RTU. Seems to be working just fine. It likes warm-hot water.
That seems excessive. The instructions I read (not specific to 4-1 or 8-1) are 8 scoops per 5 liter hf. 16 ounces. If you are putting 36 ounces in a 7 liter hf I think you will have paste.I think my water may have been too cold that day. I mix 36 oz at a time and use a 8:1 in a 7 liter HF. I get 12 gal RTU. Seems to be working just fine. It likes warm-hot water.
Like I said, I don't have an issue. on my 7 liter HF, 8:1 = 12 gallons which = 3 oz per gallonThat seems excessive. The instructions I read (not specific to 4-1 or 8-1) are 8 scoops per 5 liter hf. 16 ounces. If you are putting 36 ounces in a 7 liter hf I think you will have paste.
I am comparing it to Power Burst. I put 3-4 scoops in a 5 liter at 4-1 and 6-8 at 8-1.Like I said, I don't have an issue.
What are u using for your rinseLike I said, I don't have an issue. on my 7 liter HF, 8:1 = 12 gallons which = 3 oz per gallon
Why do you add more than the recommended amount? 7 quartz should be 11 scoops. Have you tried to see if ya get the desired result by using the suggested amounts? Trust the micro robots...I think my water may have been too cold that day. I mix 36 oz at a time and use a 8:1 in a 7 liter HF. I get 12 gal RTU. Seems to be working just fine. It likes warm-hot water.
I don’t have time to play around
And I’m not attempting to be a MB guru
WTF are you talking about? The scooper is 3 oz's, my HF puts out 12 gal RTU. Prochem needs to make the instructions with ounces, not scoops. I'm not going to stand there and count 12 scoops. It's faster and more accurate to use a measuring cup. I measured the scoop to be about 3 oz's. I'm not discussing this anymore.Why do you add more than the recommended amount? 7 liter should be 11 scoops. Have you tried to see if ya get the desired result by using the suggested amounts? Trust the micro robots...
One lump or two?WTF are you talking about? The scooper is 3 oz's, my HF puts out 12 gal RTU. Prochem needs to make the instructions with ounces, not scoops. I'm not going to stand there and count 12 scoops. It's faster and more accurate to use a measuring cup. I measured the scoop to be about 3 oz's. I'm not discussing this anymore.
Don't answer me because I won't respond. It's too early to deal with this crap. I need some coffee!
