- Feb 4, 2016
- 24,146
Good idea. I dropped in a stealth fan for some air flow.Higher the better.
Ozone is heavier than oxygen and will build up concentration lower. We use a 6 foot ladder bungee the unit to it. Put weight on the ladder if needed to keep it from being top heavy.
You can also use a low volume airmover to distribute it. The Stealth works well for this.
Make sure you air the space out before re-entering.
You bounce or the air does? ☺I put in fans too and bounce against the walls in a circular motion.
Your ozones?I got mine for $85 each from homedepot.com and they’ve made me thousands.![]()
