jmo
- Apr 11, 2011
- 350
- Name
- Jeremy
Legend Brands" data-source="post: 4614608" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I filled to top screw on back of blowerWhat kind of oil did you put in and how much oil did you put in?
it can be done. Not sure what blower that is but there are rebuild kits for most.Has anyone ever changed the seals or can it be done? Am I going to need a new blower?
Can you send me a picture of where the top screw on the back of the blower is?I filled to top screw on back of blower
Legend Brands" data-source="post: 4614613" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Can you send me a picture of where the top screw on the back of the blower is?
Legend Brands" data-source="post: 4614615" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Yes the plugyou're talking about the plug that is like an inch-inch and a half from the top?(I'm on a plane, so I can't blow up the picture, I can only see the preview) If so you overfilled it.
yeah, you overfilled it.Yes the plug
this one
Legend Brands" data-source="post: 4614622" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">There are only two plugs on the back the other one is at the bottom.Yeah, it's overfilled.
The bottom one is where the sight glass is on the newer ones and is supposed to be filled to the middle of the glass.There are only two plugs on the back the other one is at the bottom.
Drained and filled to proper level. Thanks Justin for the call and everyone else for the quick responses.
You are so welcome. Let me know if there's anything else I can do for you!Drained and filled to proper level. Thanks Justin for the call and everyone else for the quick responses.
