Encap-Punch Video
encapman
St Petersburg, FL
Rick Gelinas
Sometimes people wonder where and when to use Encap-Punch. Encap-Punch is our CRI approved Encap Pre-Spray. And since it's a true encap detergent, built around an encap polymer, it crystallizes beautifully. In addition to using Encap-Punch as a traffic lane pre-spray, it can be also used be used as an encap HWE rinse detergent, and as an encap bonnet/pad cleaner. This short video explains how it works.
Ne
Polymer rinses will plug up your solution lines and any tool.
Especially if it has to go thru a heat exchanger.
Trip Moses
IMOL
Savannah GA
Trip Moses
Encap Punch is the only prespray I’ve had on the truck for three months other than Encap Hydrox for upholstery. It has taken care of rat nasties and some tile. Also have done some pad capping with the crb and the Vibe. I been working great so far. It’s been nice to carry less chemicals on the truck.
Reactions: encapman
Nevada
Where the video about encapped carpet being vacuum? Everybody fussing about it not showing up in vac when post vacuuming.
Ne
Well if a polymer is.............PLASTIC
Think of that melting in your lines and clogging things up.
DUMMO!
icleancarpetz
Rafael Samson
You guys are being had....there are a couple encap products that is just as good for $12 gallon for both carpet and rug bonnet or hwe....highly concentrated no rinsing.
Imagine that....1 case for almost the cost of one gallon of punchpocket.
SteamwayPro
USA
George
