- Oct 6, 2006
- 117,226
by- Legendary- do you mean many issues or legendarily reliable?
Currently at over 2100 hours.Two very small issues with my Titan. Valve cover gasket got too hot on a 10hr job in the middle of a parking lot in August. Caused a small oil leak
And the shaft seal on the blower had a small oil leak as well. Replaced both and no problems since then.
Right now, 1628How many hours on the Titan?
a settling in issue?
I'm installing a bleed hose on mine. Seems like I have air in them but hydramaster hasn't provided any means to bleed it. Just putting a t connector on the return line.I’m not watching bubbles anymore
Finally
Exhaust headers burned in half, cheap car mufflers kept getting louder and I had no access to replace the stupid things without pulling the entire tm out of the trailer, water lines were made for hydraulic oil not water, which made the water constantly cause rust and corrosion, which clogged up the dema valve and filters which in turn caused the water to overheat. I had to rebuild the water pump twice for some reason that I never found. Picture all those things happening about once a month each time in the 6 months that I owned it
My sister recently moved to Texas. I tried to warn her. Immediately her apartment got flooded, and some health problems caused from a crooked doctor over there happened, lolTexas?
