- Feb 4, 2016
- 24,126
It took me 2 hours to vac that place.I see NO vacuum
No Lie. I vacced while Devon was on the Vibe.LIAR!
I change pads after every tankful.
Do you flip them? Have you used they greys yet?I change pads after every tankful.
I should clarify, I flip them after the first tank and change them after the second. Using the grey pads. They seem to wear down quickly. I used one set last week and they were worn out after the first tank. It depends on the type of carpet. Maybe some products provide more lubrication. I haven't tried releasit yet.Do you flip them? Have you used they greys yet?
Ever 400 to 500 ft?I change pads after every tankful.
Tankful is 6 gallons. I get a couple of thousand square feet out of that.Ever 400 to 500 ft?
You're nuts
Ps. $100 per hallway. $1700 in 4 hours, I think I can afford to change the pads.For example, I recently did 17 hallways between 500-600 sqft. I could do 3 hallways on one tank. Flip the pads and do 3 more, then they are pretty worn out.
So that's 900 sqft. Maybe I'm not using enough solution. I do seem to get good coverage though. The hallways weren't heavily soiled but had been protected during construction, leaving clean carpet under the plastic and soiled carpet on the other side. We had to even it out. Came out great. Still learning the Cimex so any input is welcome.Must be clean carpet.
I average 1 gallon per 150 ft or so with the Cimex
I'm usually 24 for ds and 48 for regular.I run 20 oz to a tankful. (6 gal.). When I use my machine, I look for the milky moustache.....
Huh?I'm usually 24 for ds and 48 for regular.
24 ounces for double strength. 4 oz times 6 gallons, 48 ounces of regular strength for 6 gallonsHuh?
