Grout Wand
Chris Brown
Chris Brown
Any one know if the seal on the grout wand has been improved so that it doesn't leak?
Chris Brown
Chris Brown
What brand wand are you referring to?
Diversified grout wand stick. Blue plastic tube with wheel roller attachment. Just wondering if the seal is now compatible with solvent sealers so that it doesn't leak.
I'm not aware of anything changing I used to use those and I would buy a viton seal pull the whole thing apart and swap out the o-ring but now that I'm slopping in moppin saigers seal, I haven't thought about or used one of those things in years
Chris Brown
Chris Brown
Thanks for the reply. I know that you use to use cobb's sealer which I have been using for years. Why the switch to saiger's sealer?
Based on your ladies gardening chapeaux, I can see why you'd be confused
The plastic kids toy?
The thing is a POS.
If you search the other forums, there’s a guy who made his own.
Home made, and MILES ahead of the junk toy they call a grout stick....
