- Aug 11, 2012
- 13,372
Saiger" data-source="post: 4638816" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Mark I was so surprised how that 4 year packed grease just literally melted away. I sprayed it all heavily and then went back to the bad areas again and as I sprayed the grease just disappeared.Cool![]()
I hope that franchise is better to you than the franchise I Serviced over here several years ago. I cleaned 3 of them over here and I fired themMark I was so surprised how that 4 year packed grease just literally melted away. I sprayed it all heavily and then went back to the bad areas again and as I sprayed the grease just disappeared.
It made that job so easy the hardest part was moving tables and chairs. Looks like I will need some more pretty soon. Only one jar left.
$400.Good money at $90 a piece
4 scoops of code red in the hydroforce mixed hot. Didn't scrub any of it. The grout near the carpet was spitting out chunks of grease from the over spray. I may bid on that too.I have a Marie Callender's coming up soon. The carpet hasn't been cleaned in a year. The grease is horrible. It should be a lot of fun. When I did the walk through my feet were sticking to the floor.
They are good to me. I use to get two free pizzas too but that manager moved on.I hope that franchise is better to you than the franchise I Serviced over here several years ago. I cleaned 3 of them over here and I fired them
I can take a pic of the invoice and the check when I get them if you like?I don't believe that pricing unless you are the only cleaner in town.
Or you live in kalifornica
It don’t matter. You know what you charge.I can take a pic of the invoice and the check when I get them if you like?
They didn't even flinch when I told them. I felt I wasn't high enough.
I would do it for 1, but I want extra meat and cheese.Jimmy will do it for the two pizzas.
The local pizza hut called after cleaning them. I thought there was a problem. They asked if I would travel to the other location. I told them it would take several days before I had the chance.They are only worth $90 around here.
Steve tell us all of the multiple steps you use to justify that price.
8 or 10 steps?
Do you prevacuum?
Pre agitate?
Any kind of post inspection?
Do you come back the next day to inspect it again?
He smiles.They are only worth $90 around here.
8 or 10 steps?
Do you prevacuum?
Pre agitate?
