360i How To
CJ-FL
Florida
CK-FL
I’ve never used one of these and am hoping to pick everyone’s brain as much as possible.. I have a few questions and please fill in what i’m missing if you’re willing.
1. Which Carpet Head and why
2. Cleaning speed opposed to standard light wand (ie... 20% slower, etc....)
3. Pricing opposed to standard light wand cleaning (ie... 20% more $)
4. Does using a carpet brush head substitute for using a CRB or still going to see a benefit in doing both?
5. Is the tile & grout head worth a damn? (Any better than CRB & standard rotary tile tool)
6. Tool maintenance and cleanup procedure.
7. Anything else you could think of.....
Reactions: Rick J and Mikey P
Brush head is the only to go in my opinion. Don't need the crb if using the brush head. Don't clean the entire residence with it. Just use it on the heavily soiled areas. Wand over it to remove the swirl marks. Used properly, it's a great tool for trashed carpets. Slower than a wand but cleans heavily soiled areas faster and more thoroughly.
Reactions: CJ-FL
Heart of Dixie
CJ have the techs cuff the brush head and hood after every job.
NOTE: The plastic handles are the weak link.
Have them baby the handles and every week, just make sure the little handle bolts are still snug. Do NOT let them pull it up steps by the handles! In fact, just order a replacement set today and keep it in the office.
Somewhere here I posted a tutorial on using steel to reinforce them, so search or ask Fred.
Reactions: CJ-FL and Mikey P
It was said the handles are different now.......I don't know if that is true or not
Heart of Dixie
Thank you
Reactions: FB19087
It takes a little common sense to avoid damaging surfaces and the machine itself. Metal transitions, HVAC floor vents, tile edge, wood floor edge.
It is best to get around those hazards with a wand.
Always slow it down near transitions the gear box is sensitive if you hit metal you’ll chew the gears. The dial allows you to speed up the motor or slow it down. Slow near edges
