Shane T
- Nov 7, 2006
- 1,663
- Name
- Shane Tiegs
Pressure drops 200 psi when triggering.  Assuming it is getting adequate water to the inlet side(which I'm sure it is), is this a valve or seal problem?
								Check for debris in the unloader valve first.Pressure drops 200 psi when triggering. Assuming it is getting adequate water to the inlet side(which I'm sure it is), is this a valve or seal problem?
That's exactly what was happening with my cat 3cp pump. Cleaned out the unloader and greased it and it came right back. Could also be your check valves.I should add that there is also a hard pulsation on the pressure side.
Possible, I recently had the pump out.are you sure there are no airleaks, Shane?
Hi Shane..On every tool at all pressures
No air leaksare you sure there are no airleaks, Shane?
Pressure lose on all tools but the more flow the tools has the greater the lose.On every tool at all pressures
