The glides are very different. So it would stand to reason they would recover differently on different carpets. The Bentley is a 2” tube. I guess you have to live and die by the window. I have the 2x14 dev and would say the dry times were the same as my Bentley. The Bentley was a rattling and streaking $800 turd.
[/QUOTE
Is your glide ported on the sides?My dev glide slots are 10mm.
NopeIs your glide ported on the sides?
Yeah, so much that air doesn’t flow on most carpet types.I would think that glide would have some lock down.
It doesn’t. I’ll take a picture of the glide tomorrow. It’d be a safe bet that a different glide is what you need.Yeah, so much that air doesn’t flow on most carpet types.
Does your Devastator lock down much?
Thanks.It doesn’t. I’ll take a picture of the glide tomorrow. It’d be a safe bet that a different glide is what you need.
Makes sense. When the Devastator is locked down, all goes silent. Definitely no airflow. At least not on longer yarned carpet.You need a controlled air leak at the wand.
I take my 2" to 1.5" hose cuff and drill 4, 1/4" holes spaced evenly, at the beginning of the 2" to 1.5 " conversion point, and can push it onto the wand further to stop the leak, or back off and create a controlled air leak.
Your dry times will get much better, and you will eliminate the lock-down. This also works great for using an upholstery tool to create a small air leak so the tool doesn't lock to the fabric.
We need to get together soon. Call me.
That explains why my green glide has the slots on the ends.Greenie told me, many years ago, not to seal the ends of glides because they need a leak there. An intentional leak anywhere else is idiotic.
But I don’t like to vacuum.
IndeedIdiot
BlasphemousBut I don’t like to vacuum.
Take a Dremel or box knife and cut a channel on both ends
And try that 8 ft whip hose, that wand has too much suck to go 2" all the way
I tried the whip. Still locks. I’ll carve out some channels - I bet that’ll do it. The wand probably needs to breath.Take a Dremel or box knife and cut a channel on both ends
