- Feb 4, 2016
- 24,126
I only use the Harley to drop off O-Zone generatorsembarrassed to use the Harley?
those are good ratesI charge $200 for initial installation and $100 for every day after. We do occasional smoking and cooking odors.
Not really a lot of money when you have to go there, set up, then come back and get it. Mine has a 48 hour timer so it makes easy to do 2 days. Puts out 9000 milligrams per hour.those are good rates
Im $100 setup then $60 for 2
Im basing mine off what L.A.'s expect to pay here, not that I'm a preferred supplier and can charge what I likeNot really a lot of money when you have to go there, set up, then come back and get it. Mine has a 48 hour timer so it makes easy to do 2 days. Puts out 9000 milligrams per hour.
$300 for this 6 bedroom house.What do you charge for ozone rentals?
It all depends on the severity of the odor and size of the house. Before using the ozone generator, the house must be cleaned. The ozone is the last thing we do to remove odors that remain after cleaning. On large houses I will use 2 generators. Usually 1-2 days is sufficient.How so you tell them how long it takes to ozone a house. How many days is the average?
That's why it's so important to emphasize thorough cleaning before hand. Ozone oxidizes odors but it doesn't make dirt go awayThe ozone makes a smell of its own so you can not smell the orignal smell until the ozone smell is gone. So it is hard to tell when the smell is gone. That is what I am experiecng and I tell them the longer the better the results.
Has the potential to cause a bleaching effect.Correct me if I’m wrong, but there can’t be any moisture present while using ozone?
Have heard of a wdr job where they left ozone going over a wknd and bleached the carpet outHas the potential to cause a bleaching effect.
Too much moisture and too much ozone can cause that. I use mine mainly for cigarette smoke and cooking odors. Also great for just freshening up the airspace. If I was going to move into a new place I would like to ozonate it first. Gets rid of mold spores and off gassing of building materials.Have heard of a wdr job where they left ozone going over a wknd and bleached the carpet out
I have a locally manufactured one by a company called crystal air, 9000 mg per hour and a drieaz oasis, 2400 mg per hour.What brand of ozone generators are you using?
