- Oct 22, 2012
- 28,114
- Name
- Ron Marriott
There is no pump. That's the downfall of these types of machines. You have to connect it to a hot water faucet and use tap pressure. No ability to use detergent through the machine either. You're just using plain tap water. How ever, the machine is small enough that I am thinking of combining it with one of my pump/motor combinations and separate solution. At 500 psi and using the cfx on a 50 ft hose or less, it will give you truck mount comparable results. Rotovac makes a pump and tank to go along with unit, (ranger). You can use easily 100 ft of vacuum hose with this unit and still have good suction. I'll be using it later on today on some rugs in the shop. We'll find out how well the auto pump out works.Seems like this would be great for apts. Can the pump take hot water?
I am putting an elbow on the exhaust probably with another lint sock over it just in case it happens. A small pail under it should contain any over flow. I'll try the urinal puck in the waste tank idea as well.I hooked my RVJR up to it and waded into many apartments on their water pressure and hot H2O.
Works like a champ, but I learned early to set the unit in the bathroom or tub because they can blow a 's. it load of foam from previous cleaners detergents and scampoos
Ron, I use a 20’ length of 2” hose to muffle and carry the exhaust away from the door way (or to put into a tub). To hold it on the exhaust I use a bungee.I am putting an elbow on the exhaust probably with another lint sock over it just in case it happens. A small pail under it should contain any over flow. I'll try the urinal puck in the waste tank idea as well.
