J
JS41035
If I leave the dump valve open and clean with it open on the 870,and it will blow waste water out the exhaust. The only other scenario that I’ve ever seen waste water blowing out of the exhaust is when the tank is full and the shut off float switch is not functioning properly.
I would check the following
1. Make sure both waste tank gaskets are sealing properly. Please post a picture of the current filter side lid gasket.
2. Make sure your dump valve is shut.
3. Remove all three access points. Filter basket lid,blower filter side lid and center waste lid panel. Clean the waste tank thoroughly.
Try those things first.
8000 hours on any truck mount is amazing. You obviously have taken good care of it or it would never last that long. Troubleshooting is frustrating but doing things out of order usually just keeps your from finding the problem and can lead you in the wrong direction. 90 percent of the time it is something simple and stupid that I missed.
My guess is that there is something simple that you are missing. The higher operating rpm justmade the problem more evident. Similar to the way a 100 degree summer day exposes a problem with your radiator or cooling system.
