Arcing from spark plug boot to head around spark plug!?
Johnny
Johnny
25hp water-cooled Kohler Aegis. Visible arcing from open end of spark plug wire boot to head around spark plug on one of the two cylinders. Engine stumbles with the frequency of arcing. Replaced coil (ignition module) with attached spark plug wire and boot and spark plugs, checked connections.
Any ideas what could cause this?
Much obliged.
PS I have the factory service manual for this engine, if that would be helpful to any with this engine.
You replaced the plug wire?
Look for carbon trails, clean them off, and use dielectric grease
Reactions: Johnny
Johnny
Johnny
Thanks for the replies. I replaced the coil with integral plug wire and boot. Both old and new doing the same.
Johnny
Johnny
Old plug look ok? Any carbon tracking?
also check grounds and plug gap
Old plug looked ok. Gapped new plug to .030, per service manual. Tried a wider gap, thinking .030 might be too small, but no difference.
Block is grounded. Coils mount to block.
Johnny
Johnny
I have an appointment Monday with a good small-engine mechanic whose worked on mine before. But, of course, I have jobs on Monday, so I would like to get the issue resolved before Monday.
KevinD
Kevin Dumas
If it only does it on one cylinder check compression for a weak cylinder.
Plug may be fouling slightly and the spark will take the path of least resistance instead of jumping the plug gap.
Reactions: Johnny
Johnny
Johnny
Thanks, but no plug fouling.
Johnny
Johnny
Thanks for all your replies. The issues were incorrect gaps between the coils and the flywheel and wrong spark plugs. The new plugs had a smooth vs ribbed shaft, allowing the boots to slide up, causing arcs to the head.
Mechanic said a blown head gasket can also cause arcing, but mine seem to be good.
Smooth shaft BAD! Ribbed shaft GOOD!
That's what my wife says too.
Latest Auctions
