Let's see if Larry is all that...
Shittah tree[1] (Hebrew: שטה) or the plural "shittim" [2] was used in the Tanakh to refer to trees belonging to the genus Vachellia and the genus Faidherbia. Faidherbia albida, Vachellia seyal, Vachellia tortilis, and Vachellia gerrardii can be found growing wild in the Sinai desert and the Jordan valley.
A Shittah tree
In the Exodus, the ancient Israelites were commanded to use shittah wood to make various parts of the Tabernacle and of the Ark of the Covenant. This was most likely the Acacia seyal.
"The wild acacia (Vachellia nilotica), under the name of sunt, everywhere represents the seneh, or senna, of the burning bush. A slightly different form of the tree, equally common under the name of seyal, is the ancient shittah, or, as more usually expressed in the plural form, the shittim, of which the Tabernacle was made."
.L.T.A.
Reactions: Jim Williams
Cool.
Unfortunately they bought it at Lumber Liquidators so it will probably kill them.
Reactions: hogjowl
Loren Egland
Loren Egland
A Shittah tree
If it designates a particular torrent valley, “the torrent valley of the Acacia Trees” (Shittim) may be the lower course of the torrent valley of Kidron.—Joe 3:18
.L.T.A.
1. (Shitʹtim) [Acacia [Trees]].1. A location on the desert plains of Moab to which the encampment of the Israelites extended from Beth-jeshimoth. (Nu 25:1; 33:49; Jos 2:1) Evidently “Shittim” is a shortened form of the name Abel-shittim (Watercourse of the Acacia [Trees]). Some have identified it with Tell el-Kefrein, a low hill about 8 km (5 mi) NE of Beth-jeshimoth (Tell el-ʽAzeimeh, near the NE corner of the Dead Sea). However, Tell el-Hammam, a larger site occupying a strategic position and lying 2.5 km (1.5 mi) E of Tell el-Kefrein, is preferred.
2. If it designates a particular torrent valley, “the torrent valley of the Acacia Trees” (Shittim) may be the lower course of the torrent valley of Kidron.—Joe 3:18
*Insight On The Scriptures
Latest Auctions
