Feb 6, 2020 #1 SamIam Member Joined Aug 9, 2012 Messages 11,339 Location California Name sam miller My dev 14 has a bad leak in the brass water area quick connects need to order more quick connects messaged Tom just wondering if these are available anywhere??????
Feb 6, 2020 #2 SamIam Member Joined Aug 9, 2012 Messages 11,339 Location California Name sam miller Thats a dang wand not a tom wand and its not the wand with the leak used for illustration purposes only.
Feb 6, 2020 #3 Cleanworks Moderator Joined Oct 22, 2012 Messages 27,930 Location New Westminster,BC Name Ron Marriott Try pressure washing outlets. Looks like an open flow QC. Maybe even home Depot. Reactions: SamIam
Feb 6, 2020 #4 SamIam Member Joined Aug 9, 2012 Messages 11,339 Location California Name sam miller I looked on his website all I saw was hoses for $100 my hoses are fine quick connects leak
Feb 6, 2020 #5 sassyotto Member Joined Jun 7, 2013 Messages 1,218 Location Wisconsin Name Paul any Parker Store should have those Reactions: rwcarpet and SamIam
Feb 7, 2020 #6 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Location Benton KY USA Name Lee Stockwell Needs o rings Reactions: Hack Attack
Feb 7, 2020 #7 K KevinD Member Joined Nov 23, 2006 Messages 2,471 Location Binghamton,New York Name Kevin Dumas And some high temp o ring lube Reactions: Hack Attack and Lee Stockwell
Feb 7, 2020 #8 S scotty747 Member Joined Oct 19, 2006 Messages 875 If there open flow 1/4 inch home depot should have em. In a pinch sometimes you can flip em around and put the worn side down and the good side up.
Feb 7, 2020 #9 Lyman Supportive Member Joined May 19, 2007 Messages 1,765 Location Johnstown new york Name Lyman They are on the web site, $42 for two pairs. Reactions: SamIam
Feb 8, 2020 #10 SamIam Member Joined Aug 9, 2012 Messages 11,339 Location California Name sam miller Lyman said: They are on the web site, $42 for two pairs. Click to expand... Thanks I found it needed a new slot glide too. Is there something in should do to make these brass disconnect last longer? Wd40? Last edited: Feb 8, 2020
Feb 8, 2020 #11 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Location Benton KY USA Name Lee Stockwell Parker makes a lube for o rings. A high temperature lithium grease will work too. Reactions: Hack Attack and Small town janitorial
Feb 8, 2020 #12 Shane T Member Joined Nov 7, 2006 Messages 1,663 Location Waukesha, WI Name Shane Tiegs I prefer SS male connects and brass female.
Feb 8, 2020 #13 Rob Grady Member Joined Jan 31, 2016 Messages 609 Location Sauble Beach, Ontario Name Rob Grady Superlube. Either in a spray can or grease in a tube. Part of regular maintenance. Reactions: SamIam
Feb 8, 2020 #14 BradFenstermaker Member Joined Oct 9, 2006 Messages 1,846 Location N GA Name BradFenstermaker Northern Tool has open flow QD. Stainless too Reactions: SamIam
Feb 8, 2020 #15 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Location Benton KY USA Name Lee Stockwell Because the couplers are NOT repeatedly uncoupled there is likely very little metal to metal wear. It's all o rings. Reactions: SamIam
Feb 8, 2020 #16 SamIam Member Joined Aug 9, 2012 Messages 11,339 Location California Name sam miller I ordered new ones from the website I also needed a new slot glide for my 14 inch dev
Feb 9, 2020 #17 K KevinD Member Joined Nov 23, 2006 Messages 2,471 Location Binghamton,New York Name Kevin Dumas 3 oz. O-Ring Silicone Grease Tube Reactions: Lee Stockwell
Feb 9, 2020 #18 S scotty747 Member Joined Oct 19, 2006 Messages 875 Wd-40 will swell the O-rings. I use wd-40 ptfe dry lube or any silicon lube. Reactions: SamIam
Feb 9, 2020 #19 Wandslinger Member Joined Oct 7, 2006 Messages 1,006 Location Simi Valley Name Tom Meyer Doesnt Mitch have any? Reactions: SamIam
Feb 9, 2020 #20 SamIam Member Joined Aug 9, 2012 Messages 11,339 Location California Name sam miller Wandslinger said: Doesnt Mitch have any? Click to expand... I'll check
Feb 11, 2020 #21 Wandslinger Member Joined Oct 7, 2006 Messages 1,006 Location Simi Valley Name Tom Meyer SamIam said: I'll check Click to expand... That was sarcasm by the way Reactions: Vincent Feehan and SamIam
