- Oct 6, 2006
- 117,218
including...
HEALTHIER FACILITIES
MineralShine is alkaline by nature with a typical pH of 11.5 to 12. Mico-organisms typically grow in neutral pH levels around 7. MineralShine's high pH level naturally resists bacterial growth keeping facilities healthier while reducing odors.
and...
acts as a seal and polish if you want a shine:
MineralShine's crystalline properties create a permanent protective layer on all types of
resilient floors including vinyl, tile, terrazzo, and concrete floors which eliminate dusting, marks, and discoloration while making the surface resistant to spills, etching, and soiling. Floors stay cleaner with MineralShine and require less maintenance.
Slip resistance:
MineralShine's crystalline silica structure creates a clear, transparent, and slip-resistant floor. This 100% mineral structure forms a protective layer of crystals which increase traction while allowing oxygen and humidity transfer preventing a film-forming slippery surface common with traditional floor finish systems.
www.mineralshine.com
and...
Slip resistance:
