icleancarpetz
- Mar 7, 2015
- 1,700
- Name
- Rafael Samson
Pattern of the single layer of plywood..We all understand how it happens
His question is more directed at the unusual pattern
You have a little tractor.Why are the lines tractor tire sized
Lol...I did see a Tonka toy truck somewhere in the basement.You have a little tractor.
Amazing conclusion! Learned something new.Negative air, from a furnace RETURN line between the floor beams pulled unfiltered air thru gaps in the plywood floor, leaving filtration line in the middle of the floor
Grab a corner pull it back see if that's where the seams in the plywood are. Lee wins....Negative air, from a furnace RETURN line between the floor beams pulled unfiltered air thru gaps in the plywood floor, leaving filtration line in the middle of the floor
Yep Sam we did just that.Grab a corner pull it back see if that's where the seams in the plywood are. Lee wins....
I have to give Cliff Zlotnik of Unsmoke due credit for giving me the courage to pull carpet back to diagnosis...back in 1980
Mikey English has a new victimYes, usually with a kicker, unless a power stretcher or open seam needed closed.
Yeah I didn't fix that, just for you.Mikey English has a new victim
Took a class with Cliff and Robert Pettyjohn it was the best class everI have to give Cliff Zlotnik of Unsmoke due credit for giving me the courage to pull carpet back to diagnosis...back in 1980
