- Oct 6, 2006
- 117,054
Assuming that you have nothing else to do, what will you charge for an hour of your time to let a sanitizer work?
Is there a KFC buffet close by so you can spray and wait there?
Your applying it after cleaning the carpet. No need to rinse. What are you waiting for?
Papi's Artery Cleaner and KoochinfectantWhat’s the product you suggest Jim?
what ratio does your Ginger in chief recommend injecting?Papi's Artery Cleaner and Koochinfectant
The carpet is still unsanitary.I clean the carpet then I flood the carpet with gallons of product, let it sit an hour and then clean again. So $45.00 a gallon 1500 square feet carpet = 7 gallons $315.00 2 cleans and $315.00 so what do you charge? $1.50 a square foot then rent them 4 fans and a dehu $200 a day
Who will be the first chemical manufacture to come up with something more realistic?
Don’t make me have to call you
There's instructions on the label? What's a label?A product on the “N” list that is labeled for use as a sanitizer on carpet and upholstery, and that has a shorter duration than Mike is facing.
There are several. The key is availability at this point.
Mike gets all the credit for reading the label and wanting to follow the directions, which is rarely being done, but must be.
I use Pappy's to season my Santa Maria Tri Tip. Everyone shows up to the house if they hear I'm making it.Papi's Artery Cleaner and Koochinfectant
