Say it isn't so!
Mine is a 7 qt Jug. I believe it's a Mytee jug, but I can't really remember. I usually use a 9:1 tip so I like the bigger jug, more production, less filling. I've never had a problem with it working incorrectly due to high dilution. I think this is what I have.Where do you guys get the tall boy HF jugs? I’ve seen a few videos that some guys have a gallon and a 1/2, to 2 gallon jugs....
I WANT ONE....
DAMON? Uh, I mean Tom Cruise????
Sycorp in Richmond has them.Where do you guys get the tall boy HF jugs? I’ve seen a few videos that some guys have a gallon and a 1/2, to 2 gallon jugs....
I WANT ONE....
Say it isn't so!
I’m ordering a few...Sycorp in Richmond has them.
He only asked where you got it Saiger
Mytee Pak4-7 Big Mouth 7 Qt. Injection Bottle for Select Carpet / Upholstery Cleaning Equipment - 4/Pack
Whether you're using a pressure sprayer or extraction machine the Mytee Pak4-7 Big Mouth 7 qt. injection bottle is a must for carpet, upholstery, or automotive cleaning! Designed for holding cleaning solution, this bottle will mount to select Mytee cleaning equipment. It includes graduated...www.webstaurantstore.com
Also, I know if I don't explain and point out every little f****** thing some FMT'er will say something like, "I always use corner guards" or "Why didn't you rub your nipples in a counter clockwise direction?"
Say it isn't so!
We're all curious about the directional nipplie spinnerette. Please enlighten the soiled masses.Also, I know if I don't explain and point out every little f****** thing some FMT'er will say something like, "I always use corner guards" or "Why didn't you rub your nipples in a counter clockwise direction?"
