What spare machine parts do you keep around?
Ne
LOts of brass fittings and quick connects
And of course at least two new serpentine belts for the chevy
Did I tell you that the serpentine belt is 120 inches long?
And only an inch wide...................NOT a very good thing when it drives the pump and 56 blower along with everything else. Bad engineers
Do you have any slippage issues or does it wear out prematurely?
brass fittings, jets, QDs, o-rings, valves and rebuilds .
hi-pressure line or two
Oils, filters, plugs, belts, valve cover gaskets (if Kohler)
sprayer pump, sprayer wands, hose/tubing of various size and purpose
Misc wire connectors, fuses , clamps, fasteners, glueGoop, bailing twine and dUcktApe
are a few I can think of
..LTA.
Nevada
Im savings all my brass fitting so i can melt them down to ingots
sassyotto
Wisconsin
Paul
again, Im the odd one. If I have to replace a part (unless its useful to someone else) I ditch it. Why keep an old coupler?
I do however have new spare parts that could go out (couplers, pumpout pump, water transfer pump, etc)
Unfortunately if I took a picture of the workbench nobody would say ohh or ahh.
Ne
Ron the belt started slipping the other day and had to replace it. When it stretches an inch it's gone too far. My hands and arms are all cut up from installing that belt. Rinsed out the blower and filters to lessen the load.
Sounds like a thin belt for such a large blower. I wonder if they could have twinned the drive pulleys and doubled up the belt. You're probably not getting the full performance that the machine is capable of.
Latest Auctions
