- Dec 26, 2006
- 11,200
- Name
- Mark Saiger
You can pee through it.Good job! On one had you think it can only be used as a carpet cleaning van. Then on the other hand, that’s already all it’s good for![]()
Um.... No!Next Time call me first. I wanna experiment on your van.
Which wayYou can pee through it.
Up to youWhich way![]()
Brian.....stick to carpet cleaning and leaveThe Butler port hole also makes an easy way to get back into your van when you lock your keys inside. That is as long as you have skinny arms.
Coat hanger?No really, I have locked myself out of a Butler more than once and had to unlock it via the port hole.
Reach your arm in and up and unlock the sliding door. Like I said though you need skinny arms.Coat hanger?
Ohh...dumb me.....Reach your arm in and up and unlock the sliding door. Like I said though you need skinny arms.
I don't push a wand for a living.Dang Brian, how can you have that skinny arms if you’ve pushed a wand for a living![]()
I have filled in here and there over the years. And also opened trucks in our garage that the crew leader locked himself out of. It was easier than going back up to our front building to get the extra set of keys.I figured, I just lost my head and thought you might’ve been out in the field while unlocking the van![]()
Then it's not really a 'security access door', is it? Maybe a 'convenience door for the bad guys' door?The Butler port hole also makes an easy way to get back into your van when you lock your keys inside. That is as long as you have skinny arms.
Lol
A lot of suction there.A glory hole kinda thingy.
It is a security access door when you have hose running through it and the doors are locked. The Butler is running and it is all locked up. We do use it sometimes in sketchy neighborhoods.Then it's not really a 'security access door', is it? Maybe a 'convenience door for the bad guys' door?
Lol
