Guess what I'm cleaning today for the first time since moving to Nevada
a valve isnt going to keep the manifolds from draining out..
not usually enough water in the manifolds to cause a problem. If you've finished cleaning, turn the valve off while you do your last dry passes. The vibration will eliminate most water in the manifolds so it doesn't drip on the way out.
phake diver watched really piss me off.
and dont tell me you use the dial to remember to go back and feed the parking meter
I use it all the time to time urine treatments. You should see the stress tests the INOX watches go through. It's one tough mother. That's why I wear it. You know how I am on stuff.
further south than you
unsheduled insurance call for this arvo, 6 months old wool that dog has had puppies on...
I've only poured hot soapy water over it and scrubbed it with a brush.. :dejection:
