www.flexifelt.com
Our industrial felt adhesive pad is made with the same wool blend felt as the clear Flexi-Felt. Why is it different from the typical retail store pads? Well, we don’t use the cheap double face tape that everyone else uses. In fact we don’t use tape at all. We have a special patent pending process using an industrial strength adhesive that, once heat activated, will resist to over 100 lb of sheer force per square inch, up to 25 times more than the competition! What that means to you is, they stay on and protect your beautiful hardwood floors.
They are very easy to use: you simply cut the pad to the desired shape and peel off the backing. You won’t have to wrestle to peel the backing off, as it has been designed with an easy-to-peel backing. Simply remove the backing and apply the felt to the clean surface. By sitting on your chair you will increase the bond which is now up to 5 times better than that of any synthetic double face tape sticky pad.
Here is something unique for heavy duty applications: once in place, heat activate the Flexi-Felt with a hot iron set on polyester. Apply pressure for 30 to 60 seconds Then let it cool and bond over night and you no longer have to worry about scratching your floors.
Use the Flexi-Felt to protect your flooring and your furniture as well as making your furniture much easier to move around. The Flexi-Felt also eliminates the scraping chair noises, especially on tiles. It is in fact part of our slogan: No Scratches, No Noise, No Problem… Guaranteed.
1%rs recommend this product...
I’ve heard there’s a new wet wipe on the market. You may want to check into it.
Could have used one at a job on Tuesday
Monday night's Sushi Extravaganza hit hard.
My wife is stockpiling them at my office.
I suppose it’s for the next pandemic.
Latest Auctions
