What's the secret to leaving them soft and fluffy?
High flow?
Microfiber?
AFR?
Lots of dry passes?
The washer?
Nanotechnology?
conditioned water makes a difference too
In the sticks a lot folks are on wells that range from good to gawdawful.
same for muni systems too ...some parts of the country have better than others
Soft water and an encap rinse.
An Encap makes absolutely no sense..
What possible amount of polymer are you living behind when you do multiple dry strokes through a truckmount..
Meter Maid
The Undetective
Beats me, but Chemspec Optimal Rinse simply works.
And the difference is they load that rinse with polymer.
AlienAgent
Joe Gingerich
True!
and the PS
You're better off going stronger on the prespray than cranking the emulsifier. I'll admit, I had a nasty rental with a certified nutjob watching a few weeks ago. I cranked the emulsifier up to 6 gph and gtfo.
Those situations come up about once every two years. Cut that grease and get me the hell out of here!
Reactions: Kenny Hayes
