Does timing matter when it comes to using fans to dry as you clean?
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
We just bought the Bissel Pet Hair Eraser Turbo. Our mini sheltie sheds like no other and it does a fantastic job. Has a separate power button for the brush so you can use it for hard surface w/o the brush on. Has the little vac powered attachment for upholstery and it works well too. Easy to clean/ replace filters and dump the dirt cup. Just don't be a Marty and bump the release button while you're walking to the garbage and open it on your kitchen floor. :hopeless:
Meter Maid
The Undetective
Dayton,Ohio
I just received the two dri pods.
How long is sufficient for an average sized room? Just to get the carpet dry enough to stave off any problems.
All you can do is speed up the drying. You are not going to ward off any problems. I use 1 dri pod per room, then rotate them through other areas on larger jobs. I have 3 and am looking to add a couple more. Don't make any promises.
