I'm considering converting over to live solution hose on my reel
My main concern is how often do you replace that 250-350ft of hose? Because I replace 1 section of my hose 75ft once a year. If I have to replace all that hose every year... no way
And where can I get the hardware to convert it without getting ripped off $$$
why in the hell you running 250ft+ of hose?
ave hose run for me is 100ft, so 110 on my live reel with 50 ft sections to add if needed
That's just more hose crimps that are unneeded. QRs are known to damage delicate flooring if not properly covered, which is just another step in our job to lose time. Hose crimps need recrimped about every 6months. The fewer, the better. And I've always had 250-300ft on a hose reel. Quicker and easier to roll up. My first two years working for someone else didn't have a solution hose reel. I had to manually roll up each 50ft hose. Pain
Reactions: Jim Pemberton
umm if your running 250 ft+ your already running a live reel...
unless something is being lost in translation.. ie I should be zzz but Im here 🙃
300ft in multiple 75-50ft sections that I have to disconnect from the reel and connect to the machine. I'm wanting to do away with all the crimps and QR's and just run one long 300ft. hose on the reel and have the hardware to make it a live hose always hooked up the machine.
My main concern is how often that 3ooft is replaced.
why
And the more hose crimps and QR's, there's more troubleshooting on the job when a QR fails or a crimp goes bad
Brad Gouveia
You just need to replace 10' feet on each end maybe very few years. Just where it bend I never had a hose break in the middle.
Idiotâ„¢
Just do it. You need to experience it yourself. Like everything in life, there’s pros and cons. Only advice I’d give you is to shorten the length of the hose you have on the reel. No sense it baking 150’ of hose left on it.
Matt, I run 250’ of line off my reel. And yes, I use anywhere from 100’— right to 500’. Average run is between 100’- 200’. Yes I replace the entire thing EVERY year, sometimes every 9 months. The heat is a killer for what is still on the reel. It cooks your hose.
I also find because I run Goodyear Neptune, I get fairly bad heat loss.
You running Ineptune or Parker ?
Parker didn't fail near as often for me as steelbraid .
I replaced it every couple/three years because it uglied out, not due to fail
nevertheless...doesn't seem so virtuous to cook 100's of feet of line not in use everyday/all day.
Matt, this is how I do it and it's not a problem. I Have two lengths of hose on my live reel. the first section is 150' then the second section (Lead line) is 100'. Normally 10 wraps around my arm is enough to do 95% of my jobs.
That reminds me, I need to rebuild my Super Swivel. It started leaking yesterday.
That's why I coil and hang my hose instead of putting it on a reel. My lead hose, I order 125 ft. Gives me room to cut off ends periodically when they get weak. It is so simple to pick up a coil of hose and my inline sprayer and walk into a house. I have a couple of 50 ft lengths to add to it if necessary. The longer your hose, the more heat you lose. I don't have any houses where a 120 feet doesn't get me out the door without having a hot qd on their floor.
Just don't leave it on the spool to build heat and cook your hose. It will last fine if you unspool most of it each time. So just don't stick it all on the spool, hang the extra that doesn't get used that often. Make sure that section also has a ball valve so when you need to use it, just pop it on the front end.
Rokan had a conversion kit at one time.
FB7777
I run 125 live solution line off our Butler’s.... reason is we are primarily residential and that lengt reaches over 90% of jobs
Id suggest keeping about that much on a live reel 150 feet at most
get 2 150 sections and alternate them ,
id hate to have to replace a 300 foot line...besides most will stay coiled on the reel and ‘cook’ unless you unspool it every time
I converted over to raptor blast after @Lee Stockwell told me to
