These are solid units.
LCCFL
Eli Rodriguez
Local demo today at our supply shop here in Orlando Florida. The big rig is pretty solid on heat and vacuum. The little unit in the Nissan had a steady flow of heat and vacuum.
Edit by anon:
  • FullSizeRender.mov
    28.3 MB
    21.8 MB
uploaded to youtube so people don't have to download (browsers don't support .mov files)
Reactions: LCCFL
If all one does is HWE resi from 150' or less, I suppose.
Is there a waste tank in either?
add a scrubber/encap machine, a vacuum, tool box, uph stuff, 10 gallons of chems, spare tire and lunch and you're grossly over weight.
Reactions: LCCFL
LCCFL
Eli Rodriguez
The nissan has 33 gallons fresh/waste tank with an APO. I suppose enough to fit a vacuum, 10” CRB, and maybe a Phoenix. Weight may be of concern, but I don't believe this is set for commercial usage. The psi can run a 13” zipper w/ good vacuum. He cranked it to 12Hg and it was pretty solid @100’ of vacuum.
Nice for a backup, but overpriced in all.
Big rig had 100 gallon waste/fresh water tank.
LCCFL
Eli Rodriguez
Big rig was around $80k+ with the transit. $34k for the nissan setup.
Steamaction, you either like them or hate them. I've never been a fan. They look like something a couple of dudes built in a barn.
I'd pass!
Latest Auctions
