Subfloor drying efforts?
Every grout line throughout an entire kitchen...
Throw down floor drying panels and put vacuum on it.
Or at least poly sheeting (6-mil) and pump process air out of an LGR dehumidifier to draw moisture out of it.
Is there a basement or is this a crawlspace? If basement you need to contain the space with poly, reducing your drying chamber and use the LGR process air.
Reactions: Bob Pruitt
Im asking if that's what the cause or source of the holes are°°°°°
Fat Mike
AZ
Mike G
Possibly fixing hollow tiles. We do that but always grout in the holes
did they have termite issues? I’ve seen that before too
Fat Mike
AZ
Mike G
What is the distance between holes? They could have used the holes for their moisture meter electrode probes when checking the subflooring.???
Upon initial inspection I would’ve used thermal and had the tile pulled. It’ll delaminate with that amount of moisture.
this isnt my project, rather a hard Surface Course student's
if it were a too wet grout install issue I would expect other signs, which there isnt.
Fat Mike
AZ
Mike G
That’s why I’m pretty sure they had an issue with hollow tiles or termites. Termites is usually perimeter treatment but I have seen mid floor treatment.
hollow tile we drill holes into grout then inject adhesives then grout our pilot holes.
