for those of you who use Zippers///
sassyotto
Paul
Going to order one tomorrow. Need advice.
Titan 575 using it mostly for commercial work. Right handed
Should I go with
13 inch or 15 inch? Reason I ask is that 13 inch has 5 jets and 15 inch has 6. wouldnt the 13 inch leave the carpet drier since your using less water (one less jet) and it has a smaller footprint to draw water from so the TM vacuum is more effective.
Left hand or right hand trigger setup? I know I can switch it but may as well order it knowing that is probably the way I will use it.
Any other suggestions appreciate.
Yes I will get the tall boy handle and hybrid glide extras.
THANK YOU!
sassyotto
Paul
just thought I would give as much information rather than people asking questions that might affect any suggestions.
Appreciate that you read it though. Im honored.
Using it mainly for commercial, you're better off with the super spinner. Your 575 has enough heat and flow to power it.
sassyotto
Paul
I prefer a CRB for agitation
I may use it for residential later, who knows. But the reason right now is large commercial.
