My baby...
Meter Maid
The Undetective
Any reason I shouldn’t use the greatest carpet wand on earth to also rinse tile and grout?
Oh and F you guys...
It's okay up to about 700 psi At that point it gets pretty messy..
It's going to wear out your glide which I highly encourage..
But for light rinsing of moderately soiled vinyl and tile floors go ahead just make sure your sweep really well and that no rocks pebbles or other hard objects are stuck in the slot or holes and if you're using it on 6 mm wear layer vinyl be awful careful with even just the tax spurs that can occur on a glide as they will scratch that crap too..
Reactions: hogjowl
Meter Maid
The Undetective
But for light rinsing of moderately soiled vinyl and tile floors go ahead just make sure your sweep really well and that no rocks pebbles or other hard objects are stuck in the slot or holes and if you're using it on 6 mm where layer vinyl be awful careful with even just the tax spurs that can occur on a glide as they will scratch that crap too..
That was a resounding yes.
Just seems like all the hard surface wands suck. Or else I’d buy one.
Trip Moses
IMOL
Trip Moses
What do you rinse your wood floors with?
Trip Moses
IMOL
Trip Moses
Are there one or two cylindrical brushes under that and how many square feet can you do with one tank
1 brush 2 squeegees. 600 ft with good water management. It’s not a high production machine. Good for living rooms with Labrador Retrievers. An easy upscale that doesn’t take much space in the van.
Trip Moses
IMOL
Trip Moses
That machine is worthless. Used it.
One brush and I believe half gallon fresh and waste tanks.
Do ever use anything more than 2 minutes without bitching about it. You could earn an extra 20 grand a year with a pumice stone and a roll of paper towels if you’d quit being an overthinking woman and just get to work.
Meter Maid
The Undetective
Do ever use anything more than 2 minutes without bitching about it. You earn an extra 20 grand a year with a pumice stone and a roll of paper towels if you’d quit being an overthinking woman and just get to work.
That machine is awful.
Meter Maid
The Undetective
Paid for itself with one job. You can’t finish a job without blaming your equipment for something.
Can you even scratch your nuts without thinking. Hmm.. maybe I should get some fake nails. These fingernails I gots ain’t worth a shit.
That machine is just terrible.
Numero Uno
Caesar
Supervisor ordered 12 here,the team likes them.
As for me yet to try one .
I'm on lite duty only so .
But so far so good here...course they are new.
Meter Maid
The Undetective
That machine Lunch or whatever his name is uses is no bueno. He should be embarrassed.
Chris, if you're worried about water recovery, the TH40 is the answer to your dilemma. But for really odd areas, a tile wand will work even though the recovery isn't as good. But it'll still work with no problems
Meter Maid
The Undetective
I’m not that concerned with recovery, I just see so much bad press on all the hard surface ones, just sort of turned me off. Maybe I should give one a try. My spinner is rarely appropriate on the small tile jobs I do.
Oh my Gawd, y’all are better than tv. Not quite on the level of a bunch of 8th graders at a track meet though🤷🏼‍♂️ Since you’re a wand guru, get a
TH 40, you won’t be disappointed. DO IT!!!
Reactions: Meter Maid
