Wand test
Meter Maid
The Undetective
I’m a wand nerd... and OCD, so I just completed another wand test.
Divided my living room in half, no pre-spray, extracted half with my SS12 (6 flow, 500 psi, stock glide).
The other half got my Mach 12 2” (6 flow, 500 psi, stock glide).
Completed both sides around 4:30 pm est.
As of 7:30 pm est, the SS12 side is still a bit damp (enough to wet a paper towel).
The Mach 12 2” side is virtually dry to the touch.
No fans and dry passes as similar as can be.
I wanted the SS12 to win.
The difference in “feel” was significant.
F you guys.
F you guys.
One is 1.5 inch and the other is 2 inch. Duh! F off
Reactions: Trip Moses
sassyotto
Paul
thank you for doing the comparison. I have been looking at getting a new wand and these would be the two I would be looking at.
I too was thinking the SS would win. But then again I never used a 2 inch wand so Im wandering how that would feel after 5 hours of working.
Reactions: Living The Dream
I have a 2 inch wand made for Cleanco by pmf. Similar head and glides to the mach 12. With a 47 blower it's very difficult to move on certain carpets.
Meter Maid
The Undetective
The SS12 is pure pleasure to clean with... almost like it takes no effort.
But... the M12 with 2” tube absolutely performed better, far as extraction.
So much so that I ordered a Michael glide for it last night.
Meter Maid
The Undetective
Mike... what happened to the Wednesday delivery date for my EVO13 glide? It’s Friday evening here in God’s country and I still don’t have it.
Meter Maid
The Undetective
By the way, used both wands and the JoeDang today.
Even at 8 flow (same psi) the JoeDang left the carpet much drier than even the Mach 12 2”.
But... I hated used it.
It was a comparison between two similar wands with identical glides. The only difference being the tube size. The recovery difference was profound.
How about you STFU.
The only difference being the tube size. You're stupider than you look.
Meter Maid
The Undetective
Then you must think this forum’s namesake is stupid...
He doesn’t think tube size is a big deal.
By the way... can you perform one pull-up?
