- Oct 22, 2012
- 28,039
- Name
- Ron Marriott
I would probably be interested in one of those hard surface glide for an aw29. Is there a lot of overspray?
That there's only one way to find out.What do you think he’s going to say?
There's hardly any overspray with the devastator and all the sheer angle type wands but I haven't got around to designing the AW which has me worried due to the way the jets spray straight down We may need to make some little brass manifolds to put a shear angle on them to get it to workI would probably be interested in one of those hard surface glide for an aw29. Is there a lot of overspray?
The devastator looked good. The only other wand I could convert would be my pmf 802.There's hardly any overspray with the devastator and all the sheer angle type wands but I haven't got around to designing the AW which has me worried due to the way the jets spray straight down We may need to make some little brass manifolds to put a shear angle on them to get it to work
I don't know if we'll ever get around to making one for that low sellerThe devastator looked good. The only other wand I could convert would be my pmf 802.
I guess I can't get one for my bane.I don't know if we'll ever get around to making one for that low seller
Maybe we'll make a universal box channel offering that comes with a tube of shoe goop and 3' of bailing wire for you Jimmy types.I guess I can't get one for my bane.
I hope you pulled it all apart and got the 10 lb of floor wax stuck to the jet manifold inside that head before you gave it back to Kona silenceThe PMF wand has a horrible amount of overspray and the angle of the wand is an embarrassment. You need to be 4' tall to use it effectively.
Tom cruise tall.I don’t see your problem then
