Crb
so what?
No offense intended, I promise, but you're a janitor and pt time CC'er with a porty and a steel porty in a van (Bane)
and you also think Cimex yields great results
speaking of...
have you tried encRap with a CRB next to Cimex?
any idiot can clearly see the difference
I rest my case....
it's called a scrub and rinse/flush extract.
Um, most of that is true except for the Bane part in a vannn. That is used for a porty, but not my truckmount that is in my van. And as one pro has already stated, if a good prespray is used, usually a crb is sufficient before the rinse. (With a regular truckmount)😉
if a quality pre-spray is used in sufficient quantity, the CRB scrub before rinse is a waste of time and little more than a dog 'n pony show .
If agitation is really needed, don't be lazy and use a half azz tool to doit
